dependency warning paths truncated - cannot distinguish old from new
Upon loading my VI, I received a warning of 54 dependency path changes.  Unfortunately, if you look at the attached file, you will see that the critical first portion of the paths are replaced by ellipses.  This is not a a very useful warning.  Does anyone know how to get the full paths displayed.
(2,650 Views)
Accepted by topic author wildcatherder
If I'm not mistaken, the ellipses represent the parts of the path that are identical between the two.  What is show is how they differ.
It looks to me like GFC subVI's folder was moved down a couple levles under the GFC then VI's folders.
If you want to find the full path, you could get that information from the subVI's in the project explorer tree.
(2,645 Views)
Thanks.  I certainly didn't look at that very closely.  I found that I had mistakenly loaded an old version from two levels higher in the folder tree.  Thank goodness for revision control.
(2,642 Views)
