deploy lvzlib in linux RT target
Hello, I'm using cRIO 9068 with linux RT and i have trouble with lvzlib library. With old RT system (pharlap, vxworks), adding lvzlib.dll or lvzlib.out in the real time building, RT application runs correctly; with the linux target the same procedure doesn't work. There is a way to deploy this library with MAX or add it to the target manually?
I have found an lvvzlib.so file, but it doesn't work too. Any ideas?
(2,841 Views)
Try to have a look here.
I hope this helps!
Bye,
Licia
(2,801 Views)
