derivative of non equal space in time
I want to find 1st and 2nd derivative of an array.
The time spacing is not equal , and i need non-equal time space for my application.
Can any one suggest the easy way to do it?
(3,315 Views)
Hi sujju,
what about applying simple math like dx/dt?
How are your array elements arranged to have "non equal time spacing"?
(3,289 Views)
I tried with simple maths dx/dt and used  Derivativex(t).vi  with backward differenciation bt its not giving me good result.
(3,282 Views)
Please be more specific than "not giving me good result." What is not good about the result? Does it not generate any result? Is the result incorrect by 1%? Is the result noisy? Is the result the wrong shape?
The signal you have drawn is likely discontinuous at points B and E, so some non-smooth result would be expected there.
How many points are in each segment?
Consider the Savitsky-Golay filter for calculating the derivatives. I think someone, possibly Dr. Gray, posted a link to a means of using it on unequally spaced data.
Reampling or other  forms of interpolation may be useful also.
Lynn
(3,270 Views)
Thank u..
Will try with Golay technique.
(3,243 Views)
