design a VI to read volt
Hmm no,  i meant that you need to install the device drivers software for the DAQ examples to show up.
In other words If u have put a PCI DAQ card in your system and not installed the device drivers, then ur PC will not recognise the DAQ card.
If u have installed Drivers and insert ur DAQ card and when u power on the system, the drivers for that particular DAQ device will be automatically initialised.
So just trying installing two NI DAQ device driver CD's that come with your DAQ card.Once you have successfully done this, the labview examples for DAQmx will also show up.
Plz do mail back if u still have doubts
regards
Dev
Message 11 of 14
(737 Views)
Hi hi,
My daqcard is daqcard-Al-16XE-50 I think not compatible with LV 7.1. Is there any other way I can get those examples from DAQmx?? Pls advise, your help is needed desperately..
thks
Message 12 of 14
(735 Views)
Your card is compatible with traditional DAQ only - not DAQmx. In Measurment & Automation Explorer (MAX), expand the software listing and verify traditional DAQ is installed. If it is, your device should be listed there. The traditional DAQ functions can be found on the NI Measurements>Data Acquisition palette. In the example finder, open Hardware Input and Output>Traditonal DAQ.
Message 13 of 14
(726 Views)
Hi Doraemon,
sorry i missed out your query
But then, u had a top answer from Dennis.
Hey Dennis, Congragulations on crossing the 6K mark!. Wishing you the best  for the next milestone!
regards
Dev
Message 14 of 14
(704 Views)
