design of direct form IIR Filter
while designing IIR filters(dirtect form coeff) using advanced IIR filtering VIs, i hv found that for a given filter spec,the coeff generated by LV and matlab are different in some cases specially higher order filters. The direct coeff. of a 6th order butterworth bandstop filter, fL=65 Hz and fH= 222Hz, when used in matlab showed a considerably different respose than LV, and the step response when evaluated in matlab turned out to be unstable. can someone explain the discrepancy. Thanks.
(2,666 Views)
It sounds like they are just using different algorithms. I would suggest e-mailing into the NI support, with the Matlab script and the LabVIEW VI you are using. They may be able to find out where or how the two algorithms differ.
(2,666 Views)
