desktop pc hardware compatibility
we have a desktop PC-based RT system that we built a few years ago. When we built the system we had hardware problems- the target's network adapter we used, though being in the compatibility list (82574L chipset), did not work when RAM was more than 2GB. This was solved with the kind help of NI support (Danny Diaz), who sent me a patch driver that solved the issue. The system worked well since then.
unfortunately we had to re-install the system recently due to HD expiry. we encountered the same problem (apparently the bug was not fixed in subsequent RT module versions), but this time the patch didn't worked. we found another compatible network adapter (broadcom BCM5751 chpiset) and now we have communication, but we have many TCP-IP failures, the CPUs are at 95% use and the system is unstable.
we decided to upgrade the system- newer processor (we're currently using old Core2 Duo), and a new network adapter. the compatiblity list you have on the web seems very outdated- ivy bridge, for instance, is hard to come by today. also, our vendors do not offer systems with as little as 4GB RAM. can you please assist us with finding an available machine that is known to be compatible?
thanks,
avner
(4,019 Views)
What is your application? It seems to me that you might be ahead of the game to simply replace this patched-together system with a cRIO or two. The reduced frustration factor alone might make the change worthwhile.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,987 Views)
Hi Mike,
thanks for your reply.
The application includes data acquisition (2 multi-DAQs for DIO, AO and Ai) and image acquisition (NI frame grabber). it handles both recording, stimulation and control in scientific experiments.
we don't have the money nor the time to convert the entire system into cRIO.
avner
(3,970 Views)
Avnerw,
The following document will help you with the requirements for a desktop PC to be used as a LabVIEW real-time target.
Requirements for Desktop PCs as LabVIEW Real-Time Targets
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
William Fernandez
(3,942 Views)
Hi William,
thnanks for your response. yes, this is the outdated list I was refering to. I was hoping there's something a bit more updated.
Avner
(3,928 Views)
Hi avnerw,
You need to meet the LabVIEW minimum requirements.
In addition to that, for the LabVIEW 2013 Real-Time module you will need the requirements specified in the following document
LabVIEW 2013 Real-Time Module Readme
https://www.ni.com/pdf/manuals/LabVIEWRT_2013sp1readme_KB.html
Which LabVIEW Real-Time version do you have?
Warm Regards,
William Fernandez
Applications Engineering
(3,917 Views)
