detalization of 3D
Hi!
I have a 3D models exported to LabVIEW.
It work correctly but have low detalization. I see triangles and sometimes front elements hidden by back elements.
see example.
Also if I look to model far from the one, I see triangles.
But if I move closer I see better
and better image.
How can I improve quality of model?
(4,626 Views)
Hi Artem.SPb,
Are you using the 3D Picture Control? Also, what is the physical size of the model and is it possible for you to attach the CAD file?
Ren H.
Applications Engineering
(4,561 Views)
Yes, I use 3d-picture.
There is only one main part of full construction: https://yadi.sk/d/jeXUbOenpy9vK (100Mb) (full is 16 files, 500Mb).
I don't know physical size, I've get files from customer. May be 1 meter.
Also there is snippet of subVI for reading files.
model/texture - name of files
Scene in - all 3d picture which I'll connect to 3d-picture control.
(4,542 Views)
Accepted by topic author Artem.SPb
Hi Artem.SPb,
There are several things could cause the issue here.
1.)  It could be the limitation of the 3D Picture Control, as it is handling a fairly complex model. Try to scale the model down a bit and see if it makes any difference.
2.) The performance of the 3D Picture Control depends on your graphics card
3.) Adjusting the texture using the "Specials:Texturing Property" property node could help. The documentation is here: http://zone.ni.com/reference/en-XX/help/371361M-01/lvprop/sceneobject_specials058texturing/
Ren H.
(4,509 Views)
Thanks. It's look much better.
(4,493 Views)
