detect fall of analog input signal in DAQ6015
If I put a 5V TTL signal (4Hz) into one of the analog inputs of DAQ6105, how can I get a true or false response as the output from a labview code whenever the signal changes from 5 to 0V, i.e I am trying to get "true" output when my signal is 0 and "false" in the other case.
(2,710 Views)
You've already asked this question and received answers here
- tbob
Inventor of the WORM Global
(2,700 Views)
