detecting a change to a numerical control
Hi. I am fairly new to Labview and I was wondering if I could get some advice. My question is how do you detect a change to a numerical control. I believe I need to use a property node or a invoke node but I am not sure which one I need to uses or if it is possible.
Thanks again
Message 1 of 8
(3,785 Views)
It seems that you're very new to labview. Because there's some ways of doing that.
1- shift registers in a cycle and compare the actual value with the pass.
2 - use an event case and then, choose an event associated with the numeric control.
Or else, tell me your labview version and I can made you a small example
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 8
(3,775 Views)
You can use trhe Value Change event of the Numeric control.
See the attached VI in LV 7.1...
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 8
(3,771 Views)
Thank for that. I am very new to lab view only been using it for two weeks so a very quick learning curve.
Thanks again
Message 4 of 8
(3,767 Views)
Use the event structure.
Wiebe.
Message 5 of 8
(3,765 Views)
Hi again. Sorry for asking another question but I have managed to get stuck again.
I have managed to get an event structure working to detect a change to an input of a controller which I have turned into a sub-VI. However I now have a new problem. What I actually need to do is create a high Boolean output if there is a change to the input control, and a low if there is no change. The problem with the event structure is that it needs a change to happen before it will allow the dataflow to continue. If anyone has any advice on how to achieve this I would be very grateful
Thanks again
Message 6 of 8
(3,741 Views)
Hi dbarr,
that's easy:
create a second event case (using the same structure!) with event "timeout". Set a nice timeout-time of maybe 200ms. Wire a TRUE constant from value.changed-event and a FALSE constant from timeout case. You can also set the wire tunnel to "default if unwired", then you don't need the FALSE constant.
Message 7 of 8
(3,738 Views)
Thanks for that 🙂
dbarr
Message 8 of 8
(3,725 Views)
