determine whether a number is odd or even
Should be quite simple, i need to get a true if a number is odd and a false if the number is even.
Any ideas? I'm sure i am overlooking something simple.
Regards Ross
(11,282 Views)
Look at this.
(11,282 Views)
You can use the function 'rotate right with carry' and if the output is true
then the input is odd.
"Ross@UL" wrote in message
news:506500000008000000287A0000-1042324653000@exchange.ni.com...
> Regards Ross
(11,282 Views)
Just another solution. Now you have the choice.
(11,282 Views)
