device instance path
Hi
Guys, how do use LabView to read device instance path,
i do not think windows 7 has device instance id.
Best Regards
(7,068 Views)
@wenjie1wang wrote:
Hi
Best Regards
Why do you need to try this?  Maybe there is a better way.
Bill
CLD
(Mid-Level minion.)
(7,061 Views)
Yes, what exactly is it that you are trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,055 Views)
Yes, I want use LabVIEW to detect device is connect or not.
(7,008 Views)
There is another way is use devcon.exe and use labview to detect device through devcon.exe, but I do not want to rely on another software(devcon.exe).
(7,002 Views)
Hi wang,
you can do the same operations DevCon does on your own. All you need to do is calling into Windows API!
Seriously: When you want to retrieve information from OS API you need to learn about this. MSDN is a great place to look for those API descriptions!
(6,973 Views)
(6,966 Views)
