devicenet error 524289
When using the EasyIoMultipleDevices.vi I get the following error message:
Error 524289 unknown time-out.
I attached a screen shot.
Does anybody know what this error number means?
Is it possible to have two poll connections?
(3,003 Views)
I haven't been able to find any information on this code error. However, I would suggest starting with the SingleDevice.vi example. Make sure you follow the instructions at the top, because they have a lot more detail. If the singledevice.vi doesn't work, try the SimpleWho program.
You probably have something wired up incorrectly, or have one of the settings incorrect.
I hope this helps out.
-Josh
(3,003 Views)
-Josh
(3,003 Views)
