devicenet installation
I am trying to run a PCI-8532 Devicenet board under LabView 2014 Base.
The support software NI Industrial Communications Devicenet 2.3 does not want to load (see image below). Can anyone suggest what might be wrong?
and even the System Configuration and MAX do not load.
(4,687 Views)
Hi Mack2,
Looking into the ReadMe of the NI Industrial Communications Devicenet 2.3 here, support for LabVIEW 2014 has not been added. Therefore, the driver will not look for LabVIEW 2014.
On the topic of MAX, when you install LabVIEW 2014, you also install System Configuration 5.6. Since you already have a higher version of MAX on your computer, the driver will not install an older version.
Robert R. | Applications Engineer | National Instruments
(4,654 Views)
Does this mean that DeviceNet is not supported in LabVIEW 2014 at all? Do you know when LabVIEW 2014 will support DeviceNet?
(4,645 Views)
Hi chembo,
We will be releasing a new version of NI-Industrial Communications for DeviceNet to add support for new targets and for LabVIEW 2014 and it is currently in development.  Thanks!
Matt S.
Industrial Communications Product Support Engineer
(4,627 Views)
I need to know if the new version of NI-Industrial Communications for DeviceNet to support LV2014 is released or not yet ?
BR,
FL
(4,426 Views)
