dfdt digital filter design filter ,i designed a filter but when i generate labview code and use it ,my wave's amplitude seems down,why???!
what 's wrong with my programe,filter fs =8000hz,low cut frequence is 100hz.ni3.png
(3,173 Views)
Isn't this basically the same question you asked in your other threads?
(3,144 Views)
no,in this question i used dfdt tool to design filter ,in that question,i used the origin vi in labview.i had solve that question already.
any mistake in this programe?
i desired a filter and wanner use it in labview ,the setting is below
(3,139 Views)
after i design the filter,the labview give me a lvproj and i opend it get the filter vi ,but i dont know if i used right,i put the signal direct in to the x,the picture is below.thank you~
(3,135 Views)
