diadem report generation from LabView: textbox, textobject, table
Hello everybody,
I'm trying to generate a report from LabView and want to use DIAdem reports as templates because they easy (I thought) to configure and design.
Well, I managed to include several pictures and textboxes that I can fill dynamically with the information I want using the report generation vi, and I also need to include a bunch of statistical data in the report together with the name of the variable. e.g. it's supposed to look like this:
testname: name1
mean:       35
std:           12
so, basically it's a table with strings and numbers that also variies in size (rows) depending on the test. I came up with three ways of doing this but I ran into some problems when it gets into detail:
1. using a textbox:
I'm using DIAdem 10.2 and I'm aware that textboxes can handle multiple lines but when I feed a string separted with \r\n to the textbox (from the string input array of the report generation vi) only the first line shows up???
2. using a textobject:
will result in an eaven more professional look of the report since text can be formatted, but it seems not to be possible to acces a textobject via the report generation vi. Is that correct or is my vi corrupt?
3. using a table:
in DIAdem it is possible to define a channel of strings which can be used to fill the table but I guess it not possible to create such a channel in LabView, is it?
So, I'm pretty stuck on this issue. Does anyone have an idea
David
(3,962 Views)
I found an answer to #1: the report generation vi uses a sub vi called "PushDataToDIAdem.vi" that includes a function picking the first from a multi line string. Going around this function will result in a multi line string in a text box in the DIAdem report.
David
(3,948 Views)
Hello!
Directly with LabVIEW is very difficult to reach the textobject to format.
The easiest way is to save you data (and also you text channels) in a file.
From LabVIEW you can start a DIAdem script
With the LabVIEW DIAdem connectivity VI you can say to LabVIEW to start a script:
http://joule.ni.com/nidu/cds/view/p/id/204/lang/de
In the script you can implement all your reports, layout, textbox textes,....
Best regards
Ken
(3,923 Views)
