dialog ring item selected
I have a dialog ring and I would like to know if there is a way to get the text of the item selected.
Thanks in advance,
ToNi.
(4,163 Views)
 Esay : use a property node, as shown below
Message Edité par chilly charly le 01-07-2006 12:53 PM
Chilly Charly    (aka CC)
(4,164 Views)
Hey,CC
      Good solution, thanks for giving such solutions, can you please explain me something more about the Property node, for which applications we can use it, and what are the benefits of it????
Nishant
(4,156 Views)
Property  nodes are the tools we have to control the behaviour of front panel objects. However, their use is not limited to that use only. Open the "Serach the LabVIEW bookself and search for "Property nodes". There are hundred of references.
The best thing you can do is explore
(4,149 Views)
Ok, but it works if you have checked in properties ring the sequential values... but I think if you add items to dialog ring with its custome value for each string.... it doesn't works.... because the array string save the string in the positions of array 0 to n and these positions are not right when you customize your values for your strings in the dialog ring and you don't use sequential values. Also the property value of the dialog ring returns you the custom value you are associated to the string when you add it to the dialog ring, this value isn't 0 to n in this case, for example, if you add the following to the ring dialog:
string1 129
string2 12
stringN 234
the value property if you select the string1 item, returns to you the value 129 and not 0 and then you cannot use the strings property with index 129 (value property return this) to get the text of the item selected in the dialog ring, because this index (129) is incorrect, in this case, the right index would be 0 and not 129 to get the right item selected in the dialog ring with Strings property.
ToNi.
(4,148 Views)
You are right. So, after a few minutes of exploration, here is an even simpler solution 🙂
Message Edité par chilly charly le 01-07-2006 04:22 PM
(4,150 Views)
Thanks, CC
          Thanks for the such a wonderful help, and i am always glad to post the questions, because of such a wonderful responses form the masters of the games.
Nishant
(4,120 Views)
