dialog-style LED
VI-Analyzer told me to "The control labeled "Abort" is not a dialog-style control.  Because of this, its appearance will not be platform-specific.". Abort is an LED. I found no LED in my system palette. Whats the solution? Let it be?
(2,853 Views)
Either that or avoid using a LED as a control (probably a better idea, since it isn't something the user would necessarily expect).
Alternatively, with some playing around, you can customize the push button control to create a dialog button with a LED on it, but I doubt the VI analyzer would consider it to be a dialog control.
___________________
Try to take over the world!
(2,847 Views)
