difference between division and quotient
Hi all,
I stuck with something which is look like weired for me. When I was trying to divide two numbers together I got different values in term of remainder as mentioned in theattached example .. please can any body help me to know the reason. thanks in advance
Best regards
(5,411 Views)
Accepted by topic author Al-rawachy
All I did was change the format of the X to show 6 digits of precision.  It should be obvious from here.
(5,406 Views)
Hi Crossrulz,
thank you so much for your quick reply
(5,396 Views)
Just what I thought, I fiddled a little with your VI and found the suspected root cause: precision. the default setting is "significant digits" which means how many overall digits are important to you, it can be changed to "digits of precision" which means how many digits past the decimal point you want displayed. LabView still keeps all of the information in the wire, regardless of how many digits you ask to be shown, and thus uses that in the subsequent calculation. You saw a number that rounded up, but in reality lacked a few decimals.
EDIT: Cross beat me to it, that's some fast coding!
(5,388 Views)
yeah, you are right.  I have know idea about it before.
Is there any way that make the labview follow the siginificant digits because it is really important for me to have an acuurate result? Thanks in advance
(5,381 Views)
sorry, no idea**
(5,379 Views)
Like I said, LabView ALWAYS follows the significant digits and the full precision of the result, regardless of what it shows you. The representation options are just for user readability, but LabView will always use the most accurate representation available unless you specify the opposite.
(5,349 Views)
