difference between process and library
could you tell me the difference between Process and Library ?
Thx,
Samer,
(3,644 Views)
Hi, Samer,
I think your question is slightly icomplete...
Anyway,
"...A Process is a naturally occurring or designed sequence of changes of properties or attributes of an object or system.
A Library is a collection of information, sources, resources, and services: it is organized for use and maintained by a public body, an institution, or a private individual..."
(c) Wikipedia
(3,627 Views)
In fact, could you answer these questions ?
1- when i use "Get Process List.vi" i got an array ouput of "process and Library" names, why there is library names ?
2- when i cretate a process using "Create process.vi" i don't see the process name in the explorator, i just found it in MAX and in variable manager, why ?
3- when i create a shared variable in the process above i just see this variable in the variable manager but i don't see it in MAX, why ?
Thx,
Samer,
(3,617 Views)
Hi Sameer,
In NI terminologies Deployed Shared Variable "Library" is called as  "Process". This terminology is carried forward from Lookout to Labview DSC.
Vijay Jayabalan.
(3,596 Views)
