difference between sensor and transducer
     Can anyone tell me exactly what is the differene between a "sensor" and a "transducer"?
kiranmayi
Message 1 of 12
(17,242 Views)
Hi Kiranmayi
A sensor is a device that responds to a physical stimulus (as heat, light, sound, pressure, magnetism, or a particular motion) and transmits a resulting impulse (a signal relating to the quantity being measured). For example, certain sensors convert temperature into a change in resistance. A transducer is a device that is actuated by power from one system and supplies power usually in another form to a second system. For example a loudspeaker is a transducer that transforms electrical signals into sound energy. Often the words transducer and sensor are used synonymously.
Transducer -> http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci213215,00.html
Hope it helps. 🙂
TN
Currently using LV 8.5
logo
Message 2 of 12
(17,236 Views)
I think nobody can tell exactly, but these are correct.
http://www.mfg.mtu.edu/cyberman/machtool/machtool/sensors/intro.html
http://wiki.answers.com/Q/What_is_the_difference_between_the_sensor_and_the_transducer
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 12
(17,227 Views)
     I heard that "sensor"  converts one form into other(it may be electrical,mechanical etc).But a "transducer" converts
any form into electrical form only.
                                                  i.e, All transducers are sensors but all sensors are not transducers.
Is this correct, parthabe?
kiranmayi
Message 4 of 12
(17,212 Views)
And the LabVIEW question here is? Smiley Happy
Message 5 of 12
(17,204 Views)
You can take this statement to be correct. Smiley Happy
A Transducer is the one that converts one form of energy (signal) into other form, NOT necessarily of electrical signal. Electrical transducer is the one that does so.
But, in general, electrical signal is the most wodely used one in industrial & process control applications nowadays. So, it is taken as the equivalent definition also.
Message 6 of 12
(17,185 Views)
you naughty veteran
kiranmayi
Message 7 of 12
(17,138 Views)
What hardware do I need to reed 1 sensor and 2 transducers into LV 8.5? Smiley Very Happy
Message 8 of 12
(17,133 Views)
Whichever one gets the job done. Smiley Very Happy
Message 9 of 12
(17,117 Views)
you need an electronic device that converts (transduces??  😉 ) an electrical signal into a series of numeric (hexadecimal) values which are relative to the electrical signal (voltage) being measured. 😄
Message 10 of 12
(17,106 Views)
