difference in hardware and software timing
Hi, everyone.
I have some questions on hardware timing and software timing.
1. What is the difference between hardware timing and software timing?
2. What does the hardware mean? PC or DAQ such as usb 6211?
3. When I use "DAQmx timing", does this mean I use hardware timing?
Thanks for your help!
(5,644 Views)
Software timing is done using the OS timer which is not deterministic. You get jitter. Hardware timing is done using a dedicated timer. DAQmx I believe uses a dedicated timer. Unless you are on a real time OS you might still get jitter but I am unsure.
LabVIEW 2012
(5,640 Views)
DAQmx uses whatever timer you specify - either hardware or software. Most DAQ cards have a clock that is used to time the acquisition. The time between samples is very precise and repeatable. That is hardware timing.
(5,638 Views)
Accepted by topic author Xiang00
Hi Xiang00,
Hardware timing is more acurate since it uses the onboard clock. Software timing is less accurate since it depends on the PC performance.
"Hardware" means the DAQ device such as USB-6211.
>.3. When I use "DAQmx timing", does this mean I use hardware timing?
Yes. You may find more information at KnowledgeBase DAQmx Timing and Sample Rates.
Yusuke Minami
Applications Engineer, NI Japan
日本ナショナルインスツルメンツ株式会社 技術部 巳波裕介
Yusuke Minami, Applications Engineering, National Instruments Japan
技術サポートウェブページ: http://www.ni.com/support/ja
お問い合わせフリーダイヤル: 0120-527196
(5,616 Views)
