different labview tab colors
I have a tab control and want to make each tab a unique color. When I try to set the color of a tab, it sets all of the tabs. Is there a way to individually set the color of each tab?
Message 1 of 16
(10,217 Views)
Right Click >> Advanced >> Allow Multiple Colors
Tim Elsey
Certified LabVIEW Architect
Message 2 of 16
(10,213 Views)
Tim, is there any way to programmatically set the color of individual tabs?
For example, I have an app where I put status information in a tab.  When an error occurs, I'd like this tab to be red.  Else, some less-alerting color.
How's that done?
Many thanks in advance,
--Scott Jordan
Message 3 of 16
(10,157 Views)
there are properties under the property nodes to do this right click the tab control go to crate go to property nodes and than go to color
hope this helps
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 16
(10,154 Views)
Thanks, Harold, but Properties | Colors does not seem to offer a tab-specific setting, so one can set the color of a specific tab.  I'm not seeing any effect from it in any case.  There are two sub-properties: foreground color and background color.  If "foreground" means the currently-selected tab, it has no effect.  Similarly, setting the "background" color property for the tab control has no effect.  I'm using LV 8.2 on Windows at present.  (I have no trouble setting individual tab colors using the paintbrush tool.)
Thanks, though, I appreciate the tip.   I'm hoping someone might have a clue as to what I'm doing wrong, or for some other way of getting programmatic tab-color-setting to work.
--Scott
Message 5 of 16
(10,133 Views)
(I hope it's clear that when I said "Properties | Color" I was referring to the Color property of the property node for the tab control.)
Message 6 of 16
(10,132 Views)
You are right you cant use tab controls "color" property when "multiple tab colors" is set to true. it works only when  "multiple tab colors" is set to False. may be you need to do it as shown in example attached.
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 7 of 16
(10,123 Views)
Properties>Pages returns an array. You can index the array for a specific page referance and select the F/G color for the page.
Message 8 of 16
(10,122 Views)
Thank you to everybody who responded, and especially to Tim for the nifty example!
Message 10 of 16
(10,052 Views)
