different threshhold values for elements of one array
can anybody tell me how to set different threshhold values to the elements of one array. I tried using the threshhold value method on one element, but it changed the values of all the other array elements, too...
(4,341 Views)
Hi Franzi,
Do you mean you want to apply different min/max value to the elements of an array ?
e.g. :     for i = 0, min=0 and max = 10
             for i = 1, min=5 and max = 10
             for i = n, min=m and max = M
Is that what you meant ?
If so, you need to have an array of the same lenght containing a cluster with min and max.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,338 Views)
I am sorry, but I don't exactly understand what you mean. If I build an array of clusters with my min- and max-values, than what am I to connect it with?
(4,328 Views)
save the words show the code 😉
hope this is clearer Smiley Very Happy
Epictetus
Antoine Chalons
(4,317 Views)
Hi TiTou,
Thanks for the VI. It solved my problem.
(4,314 Views)
You can also apply the coersion directly to the array.  Complete with an array of upper limits, an array of lower limits, and get a coerced array and "In Range?" array.
Message Edited by jasonhill on 07-26-2006 08:54 AM
(4,309 Views)
Beware In Range and Coerce - when limits are NOT included, coerced value may still be out of range! Smiley Surprised (at least, this is true in LV7.1)
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(4,288 Views)
