differential equations
hi..
i'm newbies in labview..just want to ask a few questions. i have 4 differential equations (non-linear), and it is a mass balance eqn. of activated sludge process. my question is how to design the block diagram(diff eqn) and then connect all together to get one output?
(3,028 Views)
You can use formula node to write equations.
Check here
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,011 Views)
Another approach is to reformulate your differential equations as difference equations.  Then you can loop through the arrays and perform relatively simple calculations on each element.
Lynn
(2,988 Views)
