differential using single ended mode
Hi I am using the multifunction  DAS Card which is set to single end mode as I need to use it to acquire all input signals, using single end channels. Now  I have got the corrected measured inputs in RMS voltage and I would like to get the differential value from the acquired inputs, using Labview functions. So How do I go about it?
Cheers,
Clement
(2,917 Views)
If all you need is the difference between one channel and another, the subtract function usually worksSmiley Wink. If it's more complicated, could explain with more details?
(2,904 Views)
