differents method to trigger 6259
what are the differents method available to trigger using APFIO in 6259
(3,278 Views)
Hi
Different Methods og triggering
Analog edge triggering,
analog edge triggering
with hysteresis, and
analog window triggering
 Characteristics
10kOhms Input impedance
DC Coupling
Santhosh M
(3,273 Views)
any  in between devices needed, i mean between signal and triggering channel or directly we can connect
(3,268 Views)
as per my knowledge u can connect.
Santhosh M
(3,262 Views)
thanks for yuor reply;
actually i am giving one signal at analog input channel of 6259 and this input signal is periodic, in between each cycle iat specified time delay i need to trigger my device by using analog ouput channel of 6259. i connected directly but it is not working, so can you please tell any other method..
(3,254 Views)
