differnt types (different shapes ) of wiper
Have a look at the property node for a dial: scale - scale positon - start.
Make the dial pointer transparent so that you can't see it rotate and place a line decoration over the top. The property node will rotate the scale and the decoration will stay still.
Message 11 of 18
(1,316 Views)
Message 12 of 18
(1,314 Views)
thank u...
here i have attached  a Vi regarding gyro  indictor..
in this Vi, i have made two DIAL...
DIAL1 ----> normal
DIAL2 ----> changes made according to your post in last thread
but DIAL2 is not updating properly...
somewhere i have made wrong.. please reply me....
Message 13 of 18
(1,276 Views)
If you can post a version saved for LabVIEW 8.5 I'll take a look.
Ian
Message 14 of 18
(1,269 Views)
Hi Ian
I've just seen your post and wondered how you managed to "lose" the numbers on the guage. I can follow your instructions to make the dial transparent but I cant seem to get rid of the numbers/markers.
Regards
Lee
Message 15 of 18
(1,254 Views)
Do you mean the wipers gauge?
If so, right click it, select scale, then style, then select the empty box - this will make the numbers and ticks disappear.
Ian
Message 16 of 18
(1,246 Views)
Hi Ian
Ignore my post ... I've just realised it's just a case of switching the markers off on the front panel. I was looking for some way to do it in the customisation screen!!
Cheers
Lee
Message 17 of 18
(1,242 Views)
Does anyone know if it's possible to replace the needle on a guage with a custom graphic? In my case, I really only need it to be an elongated rectangle.
Thanks in advance.
Message 18 of 18
(1,235 Views)
