difficulties when calling excel ActiveX
I use the diagram below to set the range "A1" background color to be Green.
As you can see ,the first two blocks I use the report builder blocks which were built in LabVIEW, it works well.
but sometimes , I need to call other applications ,not so simple as Excel  , and I need to build the reference all by myself, such as below:
and then ,as a practise, I tried calling Excel by the second method , but ,when choosing the ActiveX class, I was strongly puzzled ,there are so many ActiveX classes and I don't which one to choose , from which one to begin.  I can disgunish them only from their names , no more instructions.
what shall I do ?
any suggestion will be appreciated~~
(2,439 Views)
Better look for Microsoft Excel.... (care about version number)
Norbert
Expert: Geometry
(2,409 Views)
This works for me.
(2,402 Views)
Just as an aside, I don't know if you're aware but you can operate on a Range object without having to activate the Worksheet that contains it.  Also, you don't need to convert the Sheets index to a variant: the Item method will accept an integer.
Little things, I know, but I always like to tidy code wherever I can!
(2,394 Views)
