difficut in designing some part of this MATLAB program in labview
Program of Transmitter (matlab)
clear
clc
block=2;
n=1;                    %no.of users
m=2;                  %data length
sl=2;                 %spread length
chiplen=m*sl;        %chip length
itnum=30;
ebnostart=0;     %step iteration
ebnostep=3;
ebnonum=8;
%spreading sequence producing {+1,-1,+1,-1--------}
for i=1:sl
    spreading(1,i)=1-2*rem(i-1,2);
end
%spreading sequence generation ends
%interleaving sequence generation begins
for i=1:n
    for j=1:chiplen
        scrambrule(i,j)=j;
        first(i,j)=j;
    end
    for j=1:chiplen
        k=j+rem(randint(1,1,1000)*randint(1,1,1000),(chiplen+1-j));
        tmp=scrambrule(i,j);
        scrambrule(i,j)=scrambrule(i,k);
        scrambrule(i,k)=tmp;
    end
end
%interleave design ends
%the simulation process begins
for z=1:ebnonum
    ebno=ebnostart+z*ebnostep;
    snr(z)=(10.^(ebno/10))/sl;
    sigma=sqrt(0.5/snr(z));
    error=0;
    for bloc=1:block
        %transmitter section begins
        %generation of data randomly
        for i=1:n
            for j=1:m
                data(i,j)=randint(1,1);
            end
        end
        %end of generation of data
         %data spreading begins
        for i=1:n
            l=1;
            for j=1:m
                tmp=1-2*data(i,j);
                for s=1:sl
                    chip(i,l)=tmp*spreading(1,s);
                    l=l+1;
                end
            end
        end
        %end of data spreading
       %transmitting data production begins
       for i=1:n
           for j=1:chiplen
               transmit(i,j)=chip(i,scrambrule(i,j))
           end
       end
       %transmitting data produced
      %transmitter section ends
    end
end
Message 1 of 10
(3,637 Views)
Hi dsk,
what do you expect here? Do you think someone will do your work? Come on...
You should:
- describe your problem more detailed
- attach, what you already converted to LabVIEW G
- tell us the LV version you're using
Message 2 of 10
(3,635 Views)
How to solve the problem:
  1. Create a new VI.
  2. Put the Matlab Script Node on the block diagram
  3. Copy and paste your Matlab code in the script node.
  4. Run.
There, problem solved. Oh, wait, that wasn't the question? Silly me.
Then perhaps you might want to look at this: http://www.catb.org/~esr/faqs/smart-questions.html
Message 3 of 10
(3,627 Views)
in this how can inter change the vale for interleaver then this same problem is again data genration...
Message 4 of 10
(3,600 Views)
You're on the wrong site. http://www.mathworks.com/ is where you go to get Matlab code debugged and written.
Message 5 of 10
(3,595 Views)
I can not transform these line in labview sir.
how does I transform/write/design block of these lines in labview.
Message 6 of 10
(3,584 Views)
Hi dsk,
when you're not able to program a simple element swap of a 2D array in LabVIEW I would suggest to go through the basics course offered by NI:
One more (maybe more intuitive) way:
Message 7 of 10
(3,575 Views)
And sir these line are also creating problem to design(in above whole program)
for s=1:sl
                    l=l+1;
                end
Message 8 of 10
(3,561 Views)
Hi dsk,
spreading(x,y) is just a 2D array, which gets indexed with (1,s). The indexed value will be multiplied by "tmp" and then placed into the 2D array "chip" at index (i,l).
What part is it that is not solvable for you?
Is it the part of indexing an array?
Do you have problems in multiplying two values?
Don't you know how to use ReplaceArraySubset?
Or can't you increment some loop indices?
Come on, do some programming on your own...
Message 9 of 10
(3,556 Views)
Still i have problem
for j=1:chiplen
    end
Message 10 of 10
(3,532 Views)
