digial waveform index out digital lines
The second attachment is what I am trying to do. I want the user to select the analog channels (working ok) and then select digital channels (not working) and the add these in the order they selected to a chart (not working). I was using the first vi as a learning experiece to try and incorporate into a more robust program. So the problem I have now is getting the digital channels to be a seperate waveform for each channel the user selects and adding that to the analog signals.
Message 11 of 14
(886 Views)
I got the original post completed. I can close this out and maybe start a different post about the digital and analog signals in the same graph. Thanks for your answers they did allow me to get the data from a digital line and onto a chart.
Message 12 of 14
(878 Views)
can i get this solution in v8 please
Message 13 of 14
(794 Views)
These are the vi's used. Strip out the digital and analog channels then send to setup vi.
Message 14 of 14
(778 Views)
