digital analog in one queue
I want to create one queue for both digital and analog data. The attached vi has two. How would you get the 2 different data type feed to one queue? It would require a digital waveform and an analog waveform to get the data into one queue. Any ideas? I am using cDAQ-9172 and NI 9401 and NI 9205
Message Edited by bassinbc on 05-21-2009 11:42 AM
Message 1 of 9
(5,155 Views)
Accepted by topic author bassinbc
I think you'd need a cluster with a digital and analog waveform, and write to whichever element applies.
Jim
Message 2 of 9
(5,139 Views)
Thanks, I just relalized that.
Message 3 of 9
(5,137 Views)
Please mark Jim's post as the the solution, then.  First you will have to unmark yours by way of the Options menu to the upper right.
Message 4 of 9
(5,121 Views)
I thought he didn't like my poetry.
Jim
Message 5 of 9
(5,112 Views)
I tried to change the solved to you but it doensn't give me an option to do that.
Message 6 of 9
(5,094 Views)
Go to your message, Options menu to the upper right.  Should be a choice "unmark as solution" or something like that.
Then go to Jim's and you'll be able to mark as solved.
Message 7 of 9
(5,092 Views)
He DID like my poetry!
Jim
Message 8 of 9
(5,073 Views)
Is there a version 8 to this solution or could we just get a block diagram in jpg?  Thanks.
Message 9 of 9
(4,966 Views)
