digital filter reset by waveform chart
I am using a digitar IIR filter. I display the output of the filter on a waveform chart. When I clear the graph the filter resets. I've wired a constant False to the reset filter terminal. Any help is appreciated.
(3,444 Views)
Hi acasey!
I set up a small VI using the Digital IIR Filter.vi and was unable to reproduce this behavior.  Let me ask for some additional information:
  1. What version of LabVIEW are you using?
  2. How are you clearing the Waveform Graph?
  3. Is the code running in a loop?
Also, you may want to read through this related forum post and see if that helps you out.
David_B
(3,421 Views)
