digital fortran dll and labview interface
can anyone of u guide me to interface digital fortran dll and
labview.....
i wud be more happy to know even the settings for it. thank you.
(3,393 Views)
There are general instructions in the shipping document called "Using External Code in LabVIEW". You can view this by going to Help>Search the LabVIEW Bookshelf. You use the Call Library Node Function and specify the parameters per the dll's .h file. LabVIEW 8.20 has a wizard that will do this for you.
(3,391 Views)
Just one caveat before trying the wizard. You need the .h file that goes along with your .dll. Otherwise, the wizard won't work. Speaking from experience. Smiley Mad
Spent the last couple of days trying to get 3rd party VC++ into a .dll (didn't work), into a format that I could use in CIN (didn't work) and Math script. (ditto ditto ditto)
I just upgraded to 8.2 so I'll use the .dll wizard!!! Didn't work. (no header file) Smiley Indifferent
Eventually got everything humming along with ActiveX. Smiley Happy
PaulG.
Retired
(3,382 Views)
Hi Naveen,
You need to use the "Call Library Function Node " function in LabVIEW to call any external dll. With this function you can select the dll and specify the input and output parameters. Here is a link to a sample LabVIEW code that calls a User32.dll to play Window sound file.
Tunde.
(3,364 Views)
