digital plot off by 1/2 cycle
hi,
i have a digital waveform plot.  if you run my vi you will see that the Plot 0 signal is ending half a cycle earlier than the other signals.  i actually think that it is starting 1/2 a cycle earlier but not sure what or how to fix.
thanks
(3,125 Views)
Your plot #1 is configured with a different "transit location". Reconfigure the plot legend as follows (or simply make sure that pll plots use the same setting, whatever the setting is that you want. :))
Message Edited by altenbach on 04-30-2008 11:25 AM
(3,113 Views)
thank you,
i didn't even realize you could right click on that
(3,094 Views)
