digital pulses with counter
with a m series (PXI 6229) and a s series (PXI 6122) board we are performing various analog in- output tasks. The (constant) sample clock of all these operations is available on a PFI line and a PXI trigger line. Here we also want to use counters for generating pulses after  a certain  number  of  analog in/output  operations,  e.g. to count the number of analog in/output operations via counting digital pulses on the PFI or PXI trigger line and  to generate  one  digital  pulse for example every 100 ticks of the analog in/output sample clock. We got this working under traditional NIDAQ and a different combination of boards, but with NIDAQmx things seem slightly different espcially with programming counters.
Does anybody have any idea?
Thanks a lot in advance!!!
(2,519 Views)
Hello Werner
I found an example that maybe will help you. Look at this link:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=C94909EF79300847E034080020E74861&p_...
I hope this helps
Manuel
(2,498 Views)
