digital read in very long
I have the problem that the read in of my data needs a very long time. I have deleted all the synchronization and timing in my attached vi, so it's easier to see my problem.
On the front panel, there is an array of clusters of arrays. Each cluster is made of three arrays: for the time, for the digital lines and for the analog lines. In the first step I create arrays of the size of my time steps (each time step represents 1ms and is later clocked with a master clock, not in this program) seperately for the analog analog and the digital lines. In the second step, I change the arrays to waveforms, and these waveforms I write to the different analog out and digital out tasks.
Is there a more simple way to convert and give out much data like this?
Thanks for your answers,
Tim
Message 1 of 1
(2,297 Views)
