digital sample rate
Is there a way to set the sampling rate for digital inputs?
In am using an 6032E Daq board. I use two VI's: Port Config and Port Read, but there I cannot set the sampling rate.
The only thing I found with rate is for handshaking.
I still have an other question then: in the same VI, I want to read from an Analog input and from a Digital input. I already wrote that VI, and it runs, but is there something I must consider when reading from both analog and digital inputs at a time?
(2,769 Views)
You cannot set a sampling rate for digital operations on an E-eries DAQ board. The port is static, meaning that there is no timing circuitry controlling the port. It is updated or read by software command only.
You configure the port once, but you must call port read each time you want read from the port, and port write each time you want to update the port.
(2,769 Views)
