digital waveform output
This thread was started in 2006.  You should have started a new thread.  Event though your question is similar, a new thread will get more responses.
You can download the specs for your instrument at NI's website.  Just go to ni.com and type in your instrument (PCI-6602) inside the search box.  From there you can find the spec sheet.  If the device doesn't support hardware timing, you will have to either find a device that does, or change the timing scheme.
- tbob
Inventor of the WORM Global
Message 11 of 11
(1,501 Views)
