digitize function in agilent 548xx driver?
I read the examples in Agilent 548XX Series Certified LabVIEW Plug and Play (project-style) Instrument Driver. I don't find digitize function between configuration vi and read measurement vi. How does that work? Or do I miss it?
I would like to record the ratio of Vp-p from two channels with 10 Hz siginals.  Can you point me in the right direction?
(3,335 Views)
Is this Instrument Driver from Agilent or for the Instrument Driver Network.  Will you please post a link?
ColeR
Field Engineer
(3,310 Views)
It's from NI website. Here is the link.
(3,302 Views)
Hello ttcixi,
Correct me if I'm wrong, but I believe you just need to take the Waveform info and then do a little math to get this information.  It doesn't look like the functionality you are looking for is built into the driver.  Here's how I would do it.
ColeR
Field Engineer
(3,272 Views)
Thank you. I realized there is the digitize command in 'actn measurement acquire.vi'. I tested the program and it's working.
(3,255 Views)
