disable VI server in EXE
Hi All,
Is there a way to permanently disable VI server in EXE? Currently, I have an EXE built using application builder and in the ini I can set the VI server to TRUE and the assign the port number to listen on. This poses a great security threat to my application as anyone using my app can enable VI server and basically hack it using property/invoke nodes - like assign values to controls or retrieve indicator's values.
Ritesh
Message 1 of 8
(3,889 Views)
So, you are worried about someone that can do the same things as an operator?
Message 2 of 8
(3,875 Views)
Yes, I am worried someone with good LabVIEW knowledge could use these techniques to hack my application.
Message 3 of 8
(3,850 Views)
How would that be hacking your application? Your code is still hidden. Your allocation can be manually controlled and read. How is that less of a hack?
Message 4 of 8
(3,837 Views)
I have few global vairbales in my application which stores the information whether the app is in demo mode or in full featured mode. If the user can somehow get to know where those globals are stored in the EXE and the usage of those globals and set their value using VI server then he/she can easily convert a demo app into full featured app.
Message 5 of 8
(3,830 Views)
That's why you should use the Third-Party Licensing and Activation Toolkit
Don't do your own scheme!
Message 6 of 8
(3,826 Views)
Does it mean that the bottom line is VI Server can not be disabled in EXE?
Message 7 of 8
(3,821 Views)
Accepted by topic author LVCoder
It means that if you want something robust, use the appropriate tool. I'm not convinced that you can get to a shared variable with VI Server but if you've tried and done it, change your protection scheme.
Message 8 of 8
(3,816 Views)
