disable or hide page on tab control
Is there any way to disable or hide one page of a tab control using a property node and some element from the user interface.
I'm using LV 7.1.
I'm attaching an example of what I would like to do.
Any help would be appreciated
Eric
Message 1 of 18
(13,050 Views)
I'm using LabVIEW 8.
In the Help files, there is a topic about configuring pages programmatically.
Anyway, I saved the attached VI in 7.1 format.
Message 2 of 18
(13,036 Views)
Does this help?
Use help and you will see the explanation of the different modes for use with the different properties.
Beat to it
Message Edited by Ashe on 02-10-2006 01:10 PM
Message 3 of 18
(13,036 Views)
Hi:
Oh, I see that someone worked faster than me, anyway I will post my work so it doesn''t get useless. I couldn´t see your VI since I'm one of those dinosaurs still using LabVIEW 7.0. I've made a small VI that shows how to make visible/invisible the pages on a tab control. Hope this helps you.
Robst.
Robst - CLD
Using LabVIEW since version 7.0
Message 4 of 18
(13,028 Views)
Thank you that's exactly what I was looking for!!
Message 5 of 18
(13,013 Views)
I have problem with my VI's GUI. In my Front Panel have a lot of sensor,
ex :i have THA's sensor, when i click it, it have to change to tab "THA",
after that, i want to comeback tab " EFI simulator" i click " back" button. That is my problem.
Can any one help me to solve this problem.
Message 6 of 18
(12,085 Views)
You can use an event structure and change the value property of the tab control when there is a value change event for the back button.
Ben64
Message 7 of 18
(12,077 Views)
You probably need to go through the LabVIEW tutorials since all you have right now is a Front Panel with no functionality.
When you do get around to adding functionality, you'll most likely want to use the Tab Control Value Change Event and a Shift register to store the previous tab so that you can drive back to the original tab on the Back Button Value Change Event.
*EDIT* ben is faster than I am.
Message 8 of 18
(12,076 Views)
Please download the attachment and try, and do not forget to join the Labview Team Indonesia Labview Team Indonesia
Message 9 of 18
(12,061 Views)
Thank you so much. I did.
And i have more question: Do yous ever programing for ECU use LabVIEW such make ECU, caculate ignition timing, mearsure gas fuel, make igintion map,.... can yous help me do this?
Message 10 of 18
(12,048 Views)
