disable the state of a visa resource control
Hello community,
is there a way to disable and grey a visa resouce control?
Thanks in advance
Message 1 of 12
(3,810 Views)
Hi GeMiTa,
yes, there is!
You use the same "disabled" property as you would use with any other control too…
Message 2 of 12
(3,808 Views)
You mean the Resource Names inside the control or the Resource Control itself? If its the control, then as GerdW suggested you can use the direct property.
Message 3 of 12
(3,797 Views)
I too thought that a Visa Control should have the same top level properties as any other control but this does not seem to be the case. On my front panel i am not able to select a state for my control because it is deactivated.
Message 4 of 12
(3,792 Views)
Hi GeMiTa,
for me it works nicely and "as expected":
I also have the property available in the control's property dialog window (using LV2009 right now)…
Message 5 of 12
(3,789 Views)
This is wiered, I too see the same that the "Disabled" property is disabled on the front panel. But on going through the Control>Properties I am able to enable it back again.
I am wondering what is the reason behind this or its a bug?
Message 6 of 12
(3,785 Views)
Duplicate
Message 7 of 12
(3,785 Views)
exactly P@Anand
gives the feeling of a bug !
Message 8 of 12
(3,776 Views)
just checking in LV2011: no problem here, disabled property is available from properties dialog as expected…
Message 9 of 12
(3,773 Views)
missing information
i am using LabVIEW 2013
Thank you GerdW and P@Anand
Message 10 of 12
(3,771 Views)
