disable the state of a visa resource control
@GerdW wrote:
just checking in LV2011: no problem here, disabled property is available from properties dialog as expected…
Did you check in the Front Panel Control> Advanced>Enabled State ? I am seeing this issue in LV2012 version.
Message 11 of 12
(449 Views)
Hi PAnand,
no, I didn't check the context menu -> advanced menu. Yes, it's a shortcut for the property dialog window, but I use that shortcut very seldomly.
And yes, the same problem with LV2009: in the Advanced menu you cannot select the active state for a VISA resource control.
So we conclude: there are (atleast) 3 different ways to set the disabled state of the control and one of them is broken…
Message 12 of 12
(442 Views)
