disable trace on graph while running
How can I do to simply disable one over multiple trace on a graph while running ?
Thanks.
(3,036 Views)
You could select a point plot and point style no point and the trace disappears. You can do this manually during runtime or do it using property nodes.
Or you could delete the trace from the array.
André (CLA, CLED)
(3,025 Views)
Thank you for your response.
I'm surprised that nothing was provided for that directly on graph.
Regards.
(3,022 Views)
