disabled row in an array
Is it possible to disabled only a row in a control array and the others are enabled?
Thx
(4,383 Views)
The properties of all the elements in an array are identical because there is only one element type in the array. The only thing which can differ from element to element is the value.
You either need separate controls or controls in a cluster if you need to disable them individually.
Lynn
(4,378 Views)
You can also use a "mouse down?" filtering event, translate the coordinates to indices and discard if the mouse down occurred on the specified row/column.
(4,374 Views)
Is it a short code to do this?
If a change de position of my indicator and the size will it adapt itself ?
(4,362 Views)
Hey, please see the example screenshot.  This is how you  could do with a table and event structure.
Hope this helps!
Dan
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(4,334 Views)
I can't found the property that you selected in the pic.
Can you send me the .Vi ?
Thank
Paul
(4,313 Views)
The arrow (as opposed to the wrench) indicatees an "invoke Node".
Ben
(4,307 Views)
