disabled the switch for ten seconds
Hi! I was wondering that how we can disable( i.e. gray out) the switch
( say 10 seconds) after switching on the button?cheers!
(2,720 Views)
Create a property node. One of the properties allows you to disable and grey
out a control, and to re-enable it. Disable it when switched, and then
re-enable it ten seconds later.
Exactly how you DO this depends on how your program is designed.
tom wrote in message
news:a18dbc2f.0112070345.2b8ffcdb@posting.google.com...
(2,720 Views)
You shall use a property node (right click on terminal in the diagram panel and choose "create"...) and set the "disabled" property to your convenience. There are many ways to count down to ten before enabling the button again, according to how your program must work... - o
(2,720 Views)
