disabling breakpoint
Is it possible to prevent user setting breakpoint or probe in a VI?
Because I cannot set any breakpoint or probe in a VI. (right clic and no "set breakpoint" choice")
I suppose options are set for a particular execution of this VI, but what ?...
If you're thinking you know how re-enable breakpoints ans probe, contact me,
Thank you.
(3,522 Views)
I forgot to say I'm using Labview 7.1 on Windows XP.
(3,519 Views)
Check VI Properties>Execution. If the Allowing debugging box is not checked, you cannot set breakpoints or use a probe.
(3,517 Views)
OK,
Option : Reentrant execution was selected, which not allows the debugging possibililties
Thank you.
(3,493 Views)
