disabling controls on front pannel
My goal is to have a different set of controls available depending on the case that is active but I don't want too many controls out that I don't need.  Is there anyway I can enable a control (for example a string control) when a certain case is true and have it diabled for all the other cases?
Message 1 of 10
(13,921 Views)
Hi kelyb5,
i´m not sure what you mean. You can use the reference of the control with a property node. Use the disabled property.
Mike
Message 2 of 10
(13,915 Views)
kelyb5,
     What you can actually do is use property nodes and link them to controls on your front panel.  These properties can remove the controls completely for certain cases and have them come back for other cases.  Another option is to have the controls grayed out.  So link a property node to the control that you want to not have the ability to use and set up the case.  I hope this helps.
Michael
Message 3 of 10
(13,913 Views)
Every control can be disabled. Just create a property node and select "disable". Depending the input of this property node, the control will be on "enable or disable"
0 - enabled
1 - disabled
2 - disabled and grayed out
See the attached example
Software developer
www.mcm-electronics.com
PORTUGAL
Message 4 of 10
(13,905 Views)
I guess saying enabled and disabled wasn't accurate.  I want to hide the controls that I don't want to use because I will have hundreds on my screen and will only want the user to see about 1/9 of the controls when they run the program.  So I don't want to make them gray, I want them to not be seen.  I know there is a hide indicator option but that doesn't allow me, once the program is running, to make it visible or not.  I hope this helps to clarify my problem.
Message 5 of 10
(13,896 Views)
You can also make the control visible or invisible. Yuor problem will be the organization of the control.
Message 6 of 10
(13,892 Views)
But how can I automate a control being visible and invisible?  I don't want to manually do it every time.  Is there a way to use a case statement for it?
Message 7 of 10
(13,889 Views)
Certainly you can automate it using property nodes.
The attached VI shows how.
(8.5 file)
Jon D
Certified LabVIEW Developer.
Message 8 of 10
(13,879 Views)
Thanks so much for your help.  Property nodes should do exactly what I want.
Mythilt - Thanks for your example, I've never used property nodes before so it was a huge.
Message 9 of 10
(13,864 Views)
huge help*
Message 10 of 10
(13,863 Views)
