disalignment of controls frontpannel at startup
I'm using Labview 8.2 and it's is now the second program which causes this problem at diffrent computers.
But when I start a labview program some controls and graphs are disaligned at the frontpannel.
It takes a few minutes to get them back in the correct position. and saving/renaming doesn't correct it.
The next time I startup this VI the controlles are misaligned again!
I can't find the cause of this, and it should be corrected, rewritting the program isn't a option due to the complexity of the program.
What is the solution on this.
(2,553 Views)
Hi Robert-M,
can you upload an example vi with the same behavior?
Mike
(2,552 Views)
I can, but you need lot of drivers and hardware to makie it run. I saved it as a complete new .lib file and it that did the trick. I don't have it anymore in this new library file. problem solved (probably temporary)
(2,543 Views)
One action that could potentially solve the problem is to go to File>>VI Properties>>Windows Size and check the 'Maintain proportions of windows for different monitor resolutions'
KostasB
NIUK Applications Engineering
(2,540 Views)
