discarding the extra bytes in binary to text conversion
Hi I have a 349000 bytes of binary data. it contains 24 byte packets. I am picking up data by the header using while loop. in this data, there must be some half packet at the end, I dont want to pick it. How do i not pick these extra bytes during the conversion
(3,286 Views)
Zain has chosen to create double posts on the very same topic.
As I discovered his other post first I suggest to continue here!
@Zain:
Double posts are considered rude behaviour. Don't do this again!
(3,271 Views)
Sorry about the double post, I will continue here.
Yeah that's true, But i want to develop a generic solution to this that i dont have to check the length every time i need to convert hex into bin
(3,264 Views)
Hi Zain,
again you create double posts - you already got answers in your other thread and you already provided more information in the other thread.
STICK WITH ONE THREAD!
(3,254 Views)
